designercats Posted February 7, 2018 Share Posted February 7, 2018 Doe anyone have a tip to set up dimension default to measure interior walls surface to surface. One side is also an exterior wall and my interior dimension defaults to the exterior of that wall. I am new to chief interiors X9.. I only require the interior dimensions. Link to comment Share on other sites More sharing options...
designercats Posted February 7, 2018 Author Share Posted February 7, 2018 Hi Thanks for your response. I'm drawing a house up from scratch. But I'm only really interested in the interior space as I'll be doing interior renovations. When I'm drawing up the space one dimension in the manual dimension defaults to the exterior wall when \i type in the dimension. It wastes time as I need to correct each dimension and add on what was dimensioned to an interior wall. There must be a better way. Link to comment Share on other sites More sharing options...
Kbird1 Posted February 7, 2018 Share Posted February 7, 2018 2 hours ago, designercats said: Doe anyone have a tip to set up dimension default to measure interior walls surface to surface. One side is also an exterior wall and my interior dimension defaults to the exterior of that wall. I am new to chief interiors X9.. I only require the interior dimensions. These are the Settings I am using on the Current Remodel Project I just started which was also measured to Drywall.....so far so good.... Link to comment Share on other sites More sharing options...
designercats Posted April 18, 2018 Author Share Posted April 18, 2018 thankyou Link to comment Share on other sites More sharing options...
