Doe anyone have a tip to set up dimension default to measure interior walls surface to surface. One side is also an exterior wall and my interior dimension defaults to the exterior of that wall.
I am new to chief interiors X9.. I only require the interior dimensions.
Are you using the Interior Dimension tool?
Have you reviewed all the default settings?
Hi
Thanks for your response.
I'm drawing a house up from scratch. But I'm only really interested in the interior space as I'll be doing interior renovations.
When I'm drawing up the space one dimension in the manual dimension defaults to the exterior wall when \i type in the dimension.
It wastes time as I need to correct each dimension and add on what was dimensioned to an interior wall.
There must be a better way.
One of the dimension tools is Interior Dimension.
Have you tried using it?
These are the Settings I am using on the Current Remodel Project I just started which was also measured to Drywall.....so far so good....
77.thumb.PNG.327c57ec61933898b532424509c3270e.PNG78.thumb.PNG.f75432513e700acc25d89b8ca8435978.PNG
    28312
    Nikol1
    Nikol1
