RobWhite Posted February 5, 2018 Share Posted February 5, 2018 Can anyone tell me how to raise the height of the roof eave sheet. A boxed eave as per the attached section (PDF). I have tried deleting the eave sheet (which I am sure is the soffit) by unchecking the Roof Plane Specification>structure>soffit I have tried reducing the eave sub fascia I have played with the boxed eave: Higher Eaves Boxed check on Roof Plane Specification>options. Hopefully there is something real simple I am not doing...hopefully not too foolish! see the attachement eave sheet.pdf Link to comment Share on other sites More sharing options...
RobWhite Posted February 5, 2018 Author Share Posted February 5, 2018 Found it. I realize the soffit is fixed to the underside of the eaves sub fascia. By adjusting the sub fascia I can adjust the level of the soffit. This probably falls into the category of 'foolish' considering the length of time I've been a chief user! Link to comment Share on other sites More sharing options...
Kbird1 Posted February 5, 2018 Share Posted February 5, 2018 8 hours ago, RobWhite said: Found it. I realize the soffit is fixed to the underside of the eaves sub fascia. By adjusting the sub fascia I can adjust the level of the soffit. This probably falls into the category of 'foolish' considering the length of time I've been a chief user! good you got it figured out , just thought I say you don't need to use PDF's to post Images you can just use the Windows Snipping Tool in Windows Accessories ( pin it to your taskbar ) for this and Save the Image to your Desktop and drag it into the Light gray area of the Reply window. M. Link to comment Share on other sites More sharing options...
