kirbywhitetail Posted January 31, 2018 Share Posted January 31, 2018 hey how do I get all my line "walls & dimensions" to keep getting small the closer I zoom in. It used to be that way but now when I zoom in on a wall or something the line just get real big. Link to comment Share on other sites More sharing options...
Kbird1 Posted January 31, 2018 Share Posted January 31, 2018 have you changed your minimum line weight size ? in Preferences>Appearance is it 0 ? 10? i leave it on 0 Link to comment Share on other sites More sharing options...
kirbywhitetail Posted January 31, 2018 Author Share Posted January 31, 2018 yes it is on 0 Link to comment Share on other sites More sharing options...
Kbird1 Posted January 31, 2018 Share Posted January 31, 2018 have you turned line weights on by accident ? either there ot with the Icon , usually on the RH side Taskbar? all these issues maybe due to using X5 in Win10 ? not sure if you can run chief in Win7 compatibility mode and it will make a difference? Link to comment Share on other sites More sharing options...
kirbywhitetail Posted January 31, 2018 Author Share Posted January 31, 2018 Kbird1 thank you for advice, I did have the icon on . turned if off and all is good. Really appreciate it, Thanks Bill Link to comment Share on other sites More sharing options...
Kbird1 Posted January 31, 2018 Share Posted January 31, 2018 you're Welcome , try the compatibility settings , see if that helps your dimension issues perhaps .... Link to comment Share on other sites More sharing options...
kirbywhitetail Posted January 31, 2018 Author Share Posted January 31, 2018 will do, thanks Bill Link to comment Share on other sites More sharing options...
