TJDesign Posted January 20, 2018 Share Posted January 20, 2018 Good Afternoon - I have put in some half walls and some beams to an interior space. Where the half walls are, they block my beams. It appears that they are invisible above where they show on the bottom and then blocks the beam at the ceiling. Is there a different way to do a half wall so that it doesn't do that? Picture below shows what I'm talking about... that beam is drawn all the way to the window but when I put the half wall in that beam disappeared. I'm running X9 Interiors on a Windows 10 platform. Thanks in advance. Tami Link to comment Share on other sites More sharing options...
TJDesign Posted January 20, 2018 Author Share Posted January 20, 2018 Thank you for your reply - no - it's purely decorative being added. I added it using the soffit feature. Link to comment Share on other sites More sharing options...
TJDesign Posted January 20, 2018 Author Share Posted January 20, 2018 Hummm... this is happening in two places. Kitchen island to window and also going over the stairwell. thank you for taking a look. Loudon_New_Plan_c.zip Link to comment Share on other sites More sharing options...
TJDesign Posted January 21, 2018 Author Share Posted January 21, 2018 Thank you! I'll give it a try. Link to comment Share on other sites More sharing options...
TJDesign Posted January 21, 2018 Author Share Posted January 21, 2018 That worked! thank you so much! Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 21, 2018 Share Posted January 21, 2018 Those actually aren't beams, those are soffits. You can consider using actual Beams, polyline solids, slabs, solids, etc. And you can also block that soffit and it will behave better. You can also draw them 3-1/4" wide instead of 3-1/4" deep. That's about all I have for you though. I actually almost never use soffits for anything. I've never understood while so many users like them so much. Link to comment Share on other sites More sharing options...
Kbird1 Posted January 21, 2018 Share Posted January 21, 2018 Does Interiors have all the 3D solids tools? I know the "Home" Line doesn't so Soffits are your only option other than Shapes, though I thought everyone had Slabs? M. Link to comment Share on other sites More sharing options...
