Problem with puck lights on top of cabinets
DesignPro-Diane
I'm trying to use a library part to create indirect lighting (Architectural>Lighting>Cabinet>Puck Above Cabinet). Unfortunately, there don't seem to be alternative products to show continuous indirect lighting, i.e., LED strip lighting. Placed the pucks and verified with a section view that they were where I wanted them. I then opened a camera view, and it showed the fixtures had attached themselves to the ceiling above. The elevation view doesn't show the fixtures. Have attached the section and the quick ray trace I created. Has anyone else had this problem? If so, how did you resolve it? Thank you!
M Bathroom Indirect Lights - Problem .pdf
M Bathroom Indirect Lights .pdf
Hi Diane, are you sure that the lights aren't there?
Try taking a camera view of the top of the cabinets.
It looks to me like what you are seeing is the light
shining on the ceiling. By default those puck lights
are set to Spot lights. Try changing them to Point
lights and backing the Intensity way down (like to
about 5%). In the attached image the cabinets on
the right have Spot lights on the top and on the
cabinet on the left they have been changed to Point
lights.
