wnschoen Posted December 14, 2017 Share Posted December 14, 2017 Anyone have a solution for this condition? Creating custom 3D Moldings (like for a frieze board) - - the transition from a gable (angled) end to an eave ('flat') piece.. If you use two moldings the gable overhangs too far (runs past the eave). If you have one molding and turn the corner/change the angle, the profiles don't match up. I know you can do a solid to make it work, but that is a bit of a pain and makes the plan file bigger fast. Thanks. 3D Molding.plan 3D.pdf Link to comment Share on other sites More sharing options...
glennw Posted December 15, 2017 Share Posted December 15, 2017 How would you build that detail in real life? Link to comment Share on other sites More sharing options...
wnschoen Posted December 15, 2017 Author Share Posted December 15, 2017 Miter Cut and/or trim the ends to match. It is a Frieze Board with a Cap on Top - we do details similar to this all the time. Verity Garage Aug 2017.pdf Verity Garage Aug 20172.pdf Link to comment Share on other sites More sharing options...
