judyjudyjudy Posted December 13, 2017 Share Posted December 13, 2017 Using X9. I have attached a zipped plan and a view of the problem. I have tried changing the wall under the roof tab but to no avail. I have this problem often. Can anyone tell me what I need to change? Wall Issue.zip Wall Issue.pdf Link to comment Share on other sites More sharing options...
Kbird1 Posted December 13, 2017 Share Posted December 13, 2017 The Roof planes over the one story section are cutting thru the Upper story Wall, pull them back out of the wall , you may need to open the Roof Panel's DBX and check "no special snapping" to do this as that upper wall is broken into 3 sections and should really be one , that can be fixed easily by dragging either the top or bottom section of wall over the other pieces so it becomes one wall again. You will likely have to "fix" the 3D view to get all the siding the correct colour , as Eric said your default is blue siding not the champagne. Pictures can be easily add to a post with the (Windows) Snipping Tool in Accessories , I have it added to my taskbar for quick access, just drag out a selection around the issues and save the capture to your desktop and then drag the capture into the light grey area in the reply box Link to comment Share on other sites More sharing options...
judyjudyjudy Posted December 14, 2017 Author Share Posted December 14, 2017 Thanks for your help! Much appreciated. Link to comment Share on other sites More sharing options...
