dskogg Posted December 5, 2017 Share Posted December 5, 2017 I have raised roof but walls do not raise after? I have auto attic wall rebuild turned on. The structure tab in the wall shows they are at standard height. I thought ca used to raise walls automatically, should i just be manually just pulling up walls? Link to comment Share on other sites More sharing options...
dskogg Posted December 5, 2017 Author Share Posted December 5, 2017 Here is a sample plan where i raised roof off plates 10" and the walls fail to raise to meet the soffit? How would one make a roof with a high heel if the walls dont raise? Am i missing something? roof plan.plan roof plan.zip Link to comment Share on other sites More sharing options...
dskogg Posted December 5, 2017 Author Share Posted December 5, 2017 roof plan.zip Link to comment Share on other sites More sharing options...
dskogg Posted December 5, 2017 Author Share Posted December 5, 2017 see if this works roof plan.zip Link to comment Share on other sites More sharing options...
dskogg Posted December 5, 2017 Author Share Posted December 5, 2017 I am not sure what i am doing wrong? roof plan example.zip Link to comment Share on other sites More sharing options...
dskogg Posted December 5, 2017 Author Share Posted December 5, 2017 plan shows 2600 the zip file shows 0 Link to comment Share on other sites More sharing options...
dskogg Posted December 5, 2017 Author Share Posted December 5, 2017 Hi Eric, so the only way to raise roof is to do this before you build it? Because this option is not available after roof has been built? What if i had a very complex roof that was manually drawn, i have to redo roofs to raise them? Link to comment Share on other sites More sharing options...
dskogg Posted December 5, 2017 Author Share Posted December 5, 2017 i built this roof with trusses checked but there still is no option to raise roof here? Link to comment Share on other sites More sharing options...
Kbird1 Posted December 5, 2017 Share Posted December 5, 2017 Depends on what you are trying to do I think.....move the roof up or just make it Thicker / Deeper, so you can have an Energy heel Truss ? Link to comment Share on other sites More sharing options...
Kbird1 Posted December 5, 2017 Share Posted December 5, 2017 6 minutes ago, dskogg said: i built this roof with trusses checked but there still is no option to raise roof here? that is the Roof Plane DBX , not the Build Roof Planes DBX Link to comment Share on other sites More sharing options...
dskogg Posted December 5, 2017 Author Share Posted December 5, 2017 I used the transform/replicate to move roof up but walls dont come with roof. Where is the roof planes dialogue vs roof plane? Link to comment Share on other sites More sharing options...
Kbird1 Posted December 5, 2017 Share Posted December 5, 2017 If you have mostly Manual Roofs you may need to use the Edit ALL Roof Planes Tool at the bottom of that Drop down in the pic below (Build Roof Planes is at the Top) Link to comment Share on other sites More sharing options...
dskogg Posted December 5, 2017 Author Share Posted December 5, 2017 I dont want to edit all roof planes, just my upper roof. I am not quite sure I understand how this roof is supposed to work but i remember ca used to rebuild walls when roof planes were raised? I just wanted to move upper roof up so lower roof would slide under without having to manually pull up walls, easy enough to pull up walls but then i find too many times all this manual manipulation causes all kind of issues. Link to comment Share on other sites More sharing options...
dskogg Posted December 5, 2017 Author Share Posted December 5, 2017 i am sending my plan in to ca to look at, i managed to get walls to rebuild automatically with a sample plan now...not sure whats going on. Link to comment Share on other sites More sharing options...
Kbird1 Posted December 5, 2017 Share Posted December 5, 2017 25 minutes ago, dskogg said: I dont want to edit all roof planes, just my upper roof. I am not quite sure I understand how this roof is supposed to work but i remember ca used to rebuild walls when roof planes were raised? I just wanted to move upper roof up so lower roof would slide under without having to manually pull up walls, easy enough to pull up walls but then i find too many times all this manual manipulation causes all kind of issues. would of been good info in the 1st post either raise the Room Ceiling height...... if you want that room with a taller Stud height? or Select the Walls and Choose Balloon through the Ceiling in the Wall Structure DBX , this should pull the Siding up to the Soffit ...works here in sample plan... if you raised the Roof manually M. Link to comment Share on other sites More sharing options...
dskogg Posted December 5, 2017 Author Share Posted December 5, 2017 thanks Mick, i want the room height to stay the same just raise roof, in a sample plan it was raising walls and building them as attic walls, but my plan would not do this? i have auto build attic walls checked still didnt work. Link to comment Share on other sites More sharing options...
Kbird1 Posted December 5, 2017 Share Posted December 5, 2017 The Balloon through Option works ..... not sure how you plan to Frame it? It seems CA does not consider these Attic Walls ( nothing on Attic Level) hence no auto rebuild another Option is to add a BLANK 3rd floor and draw those 4 walls yourself ( using reference layer) , when you build the 3rd floor, in the DBX you get make the room height 10" high and the Floor structure 0" by deleting both joist and ply , then one wall will build on top of the other. Link to comment Share on other sites More sharing options...
dskogg Posted December 5, 2017 Author Share Posted December 5, 2017 Here is what i think is correct, i raised the roof a bunch and ca raised the walls and because i had roof trusses it made them high heels It just wasnt working with my current plan, i must have screwed something up? CA is looking at it. Link to comment Share on other sites More sharing options...
dskogg Posted December 5, 2017 Author Share Posted December 5, 2017 Thanks for looking at this, much appreciated, it is good to get help from the forum. Link to comment Share on other sites More sharing options...
Kbird1 Posted December 5, 2017 Share Posted December 5, 2017 It (likely) depends on the Order you do things , if you have a normally framed roof CA will build a knee wall on top of the existing one, if you raise the roof to support the Rafters. If you have the Trusses already drawn in , then raise it , it should enlarge the Truss on a "Force Truss Rebuild" effectively making it an Energy Heel Truss. M. Link to comment Share on other sites More sharing options...
