Sign in to follow this
madcowscarnival
exposed beam in gable
I am trying to figure out how to do a thing the "right" way.  In the image, I am trying to demonstrate exposed beams in the gable areas.  For the horizontal and vertical members I could use a soffit which gave the beams depth.  But for the angled members it appears you cannot rotate a soffit.  As a workaround I created a polyline, converted to a materials region and simply matched properties.  The problem is, there is no depth in ortho, and I can't find a method to give it depth.  I'm not required to provide a 3-D, but the client is presenting this to an HOA and it would be nice to be able to print out a 3-d pic for him.
Bonus question: is there a way to rotate the material fill to match the alignment of the length of the soffit?  I realize we're probably dealing with specific length patterns, but just curious.
Background: Version X6, rudimentary skills.
Try drawing polyline solids in elevation view for your beams.  You can make a copy of the material and adjust the angle.  Unless you mean the gable fascia ?
You can use a Sloped Soffit for some things -- like ceiling beams, but I agree with Chop -- p-solids are the way to go.
    27473
    CaptainEric
    CaptainEric
