New Computer Problems
Rosco2017
9 minutes ago, Rosco2017 said:
I bought the ripper on sale for $799.99. It was a pre- Black Friday sale. I bought everything on my list for sale. Around Black Friday seems to be a good time to buy computer parts. Lol
And just one more thing: The Ripper has a known issue with causing core temperature readings to be 5 degrees C higher than reality. Peace, Jon
There has got to be something I'm missing. I installed the new RAM and the CPU still maxes out at 99-100% making it impossible to do any other tasks on the machine. I feel like this machine should be able to handle multiple tasks while rendering. It has to be some kind of setting I'm missing. Any Ideas? Below is an updated list of my computer's parts.
Parts List:
*MasterCase Pro 5 Mid-Tower Case with FreeForm Modular System, Window Side Panel, Top Mesh Cover, and Watercooling Bracket by Cooler Master
*WD Black 1TB Performance Desktop Hard Disk Drive - 7200 RPM SATA 6Gb/s 64MB Cache 3.5 Inch - WD1003FZEX
*EVGA 210-GQ-0850-V1 GQ 80 Plus Gold, 850W ECO Mode Semi Modular Power Supply
*G.SKILL Flare X Series 32GB (4 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 (PC4 25600) Desktop Memory Model F4-3200C14Q-32GFX
*GIGABYTE X399 AORUS Gaming 7 sTR4 AMD X399 ATX 3*M.2 4-Way SLI AMD Motherboard
*SAMSUNG 960 EVO M.2 2280 1TB PCI-Express 3.0 x4 Internal Solid State Drive (SSD) MZ-V6E1T0BW
*GIGABYTE GeForce GTX 1080 DirectX 12 GV-N1080WF3OC-8GD 8GB 256-Bit GDDR5X PCI Express 3.0 x16 SLI Support ATX Video Card
*Windows 10 Home - 64-bit - OEM
*Enermax Liqtech TR4 240 AIO Liquid CPU Cooler, Support 500W+TDP and Overclocking, AMD Socket TR4 Ready, ELC-LTTR240-TBP
*AMD RYZEN Threadripper 1950X 16-Core / 32 Threads 3.4 GHz Socket sTR4 180W YD195XA8AEWOF Desktop Processor
Parts List:
How many cores are selected to be used in the Raytrace setting in preferences? I set it for about 28 to be used and that still allows me to use intensive programs like AI, Photoshop, ID etc.
Are all of your cores enabled in Ryzen Master?
Parts List:
Here is my parts list attached. The one thing that has changed is the RAM--the new RAM is 2 kits of Corsair Dominator CMD32GX4M4B3200C16. I also have added a fan controller and custom cables.
Parts List:
When you start to use more intensive programs while raytracing, you might get 'bottlenecked' at the amount of RAM that you have. I regularly work using about 46 GB of RAM, and as said before the Ripper loves all the DIMM's to be filled.
Not familiar with Ryzen Master , but make sure Chief , in the Preferences>Render Tab is not using the MAX number of cores ...default is max , I set it to 8 or 10 on my 12 core 5820K,  ( 6 physical cores x2 with HT)  computer so I can still work in other programs too.  The Raytrace will obviously be a bit slower though. If i leave mine on 12 , things get pretty hot so I don't do it any longer....
Yes. All of my cores are enabled in Ryzen Master. I dropped my cores used in Chief to 28 like yours and that solved me maxing out issue. I think I'm in the homeward stretch here. I'm not experiencing anymore crashes (knock on wood) and the changing the cores used in chief solved my CPU issue. I have some work to do tonight and I will let you know how the system holds up. Fingers crossed! Thank you for all your help.
Ryzen Master is a software available on AMD's website that can control CPU & RAM usage and overclocking. It will be slower......but still faster than 90% of the cpu's  on this forum! Fully maxed out and overclocked our systems will crush most dual Xeon systems at a fraction of the cost! I have already beat some of them rendering benchmarks here.
2
Good Stuff!! Once you get the wrinkles ironed out you will be very happy with the stability, computing and rendering power, it's the best computer I've ever had. Did you know that a Ripper is really just a Epyc processor for retail?
