bgolfy Posted November 22, 2017 Share Posted November 22, 2017 Hi, I'm a new user of CA X9 and I'm building a balcony with a glass balluster. Its default property is about 900mm. I'd like to use a balluster with 450mm of wall at bottom and 450mm of glass (top). Any idea of how can I do this? Thanks, Link to comment Share on other sites More sharing options...
bgolfy Posted November 22, 2017 Author Share Posted November 22, 2017 ... I found this ... ... will try later if it works. But, any new idea will be welcome thanks, Link to comment Share on other sites More sharing options...
MarkMc Posted November 22, 2017 Share Posted November 22, 2017 Railing, panel type, change railing height and include bottom railing, distance off floor zero BTW your question really belongs in th Q&A section 1 Link to comment Share on other sites More sharing options...
bgolfy Posted November 22, 2017 Author Share Posted November 22, 2017 Yes ... I guess but i didn't find it.. or didn't understand well. I'm a new french user (DIYer) so some technical architecture words in English are a bit not evident for me . I will try what you said and other tips I have read, when I get back home. Thanks a lot for answering. Link to comment Share on other sites More sharing options...
MarkMc Posted November 22, 2017 Share Posted November 22, 2017 1 hour ago, bgolfy said: Yes ... I guess but i didn't find it.. or didn't understand well. I'm a new french user (DIYer) so some technical architecture words in English are a bit not evident for me . I will try what you said and other tips I have read, when I get back home. Thanks a lot for answering. No problem, happens a lot with new users regardless of language. Attached quick plan- look in the railing dbx and explore settings also need to to adjust the walls below to balloon through ceiling. Balconey.plan Link to comment Share on other sites More sharing options...
bgolfy Posted November 22, 2017 Author Share Posted November 22, 2017 That's nice MarkMc, that is what I'd like to make. Merci ! Link to comment Share on other sites More sharing options...
bgolfy Posted November 22, 2017 Author Share Posted November 22, 2017 Sorry, I tried everything, it doesn't work ... what version are you using ?? if I checked "Bottom rail" I just got a very thin rail and I can change it s height ... Thanks, Link to comment Share on other sites More sharing options...
MarkMc Posted November 22, 2017 Share Posted November 22, 2017 43 minutes ago, bgolfy said: Sorry, I tried everything, it doesn't work ... what version are you using ?? if I checked "Bottom rail" I just got a very thin rail and I can change it s height ... Thanks, Check ALL the DBX pages and settings. Bottom rail is a drop down in the rails tab. I'm using X9- did you download the plan I posted? Link to comment Share on other sites More sharing options...
bgolfy Posted November 22, 2017 Author Share Posted November 22, 2017 That's very cool MarkMc !! I didn't see this at all.. I think because the selected profile was always set up to Top Rail .... even in the plan you posted. Thanks again a lot !!! Link to comment Share on other sites More sharing options...
bgolfy Posted November 23, 2017 Author Share Posted November 23, 2017 Strange balcony ... too many parameters, I'm lost. Any help ? Thank you Link to comment Share on other sites More sharing options...
MarkMc Posted November 23, 2017 Share Posted November 23, 2017 Not at computer. Suggest posting in Q&A and post a plan. That may be easier with pony wall. 1 Link to comment Share on other sites More sharing options...
glennw Posted November 23, 2017 Share Posted November 23, 2017 I am not at my computer at the moment but from memory, I think you can use a solid rail and use top rail as the glass by changing the top rail settings like height, width, material, etc 2 Link to comment Share on other sites More sharing options...
bgolfy Posted November 23, 2017 Author Share Posted November 23, 2017 Thank you both. When I get home I will try again and post the plan. Link to comment Share on other sites More sharing options...
MarkMc Posted November 23, 2017 Share Posted November 23, 2017 9 hours ago, glennw said: I am not at my computer at the moment but from memory, I think you can use a solid rail and use top rail as the glass by changing the top rail settings like height, width, material, etc Nice one Glenn, works easily. Just changed the material for the inside of the railing wall to match the exterior. Thought I would have seen that on one of the shower wall discussions but don't recall such, would work nicely there. Link to comment Share on other sites More sharing options...
bgolfy Posted November 23, 2017 Author Share Posted November 23, 2017 it seems easy. I will try at home and let you know... Link to comment Share on other sites More sharing options...
bgolfy Posted November 23, 2017 Author Share Posted November 23, 2017 Nice ... it works very well. All of my little issues around the balcony are now solved ! Thanks a lot to both Link to comment Share on other sites More sharing options...
bgolfy Posted November 23, 2017 Author Share Posted November 23, 2017 ... and why do I have that clear wood color in my Bottom Rail instead of "Beige Stucco" like exterior side ?? where, how can I change this like MarkMc last balcony posted ?? Thanks Link to comment Share on other sites More sharing options...
bgolfy Posted November 23, 2017 Author Share Posted November 23, 2017 Done ... I finally find how to re-define the railing wall ! Thanks, Link to comment Share on other sites More sharing options...
