bgolfy
Balcony with half wall, half glass
Hi,
I'm a new user of CA X9 and I'm building a balcony with a glass balluster. Its default property is about 900mm.
I'd like to use a balluster with 450mm of wall at bottom and 450mm of glass (top).
Any idea of how can I do this?
Thanks,
... I found this ...
... will try later if it works.
But, any new idea will be welcome :)
thanks,
Railing, panel type, change railing height and include bottom railing, distance off floor zero
BTW your question really belongs in th Q&A section
Yes ... I guess but i didn't find it.. or didn't understand well. I'm a new french user (DIYer) so some technical architecture words in English are a bit not evident for me :).
I will try what you said and other tips I have read, when I get back home.
Thanks a lot for answering.
No problem, happens a lot with new users regardless of language.
Attached quick plan- look in the railing dbx and explore settings also need to to adjust the walls below to balloon through ceiling.
Balconey.plan
Sorry, I tried everything, it doesn't work ... what version are you using ?? if I checked "Bottom rail" I just got a very thin rail and I can change it s height ...
Thanks,
Thanks,
Check ALL the DBX pages and settings. Bottom rail is a drop down in the rails tab. I'm using X9- did you download the plan I posted?
That's very cool MarkMc !! I didn't see this at all.. I think because the selected profile was always set up to Top Rail .... even in the plan you posted.
Thanks again a lot !!!
Not at computer. Suggest posting in Q&A and post a plan. That may be easier with pony wall.
I am not at my computer at the moment but from memory, I think you can use a solid rail and use top rail as the glass by changing the top rail settings like height, width, material, etc
  • Upvote 2
Nice one Glenn, works easily. Just changed the material for the inside of the railing wall to match the exterior. Thought I would have seen that on one of the shower wall discussions but don't recall such, would work nicely there.
Nice ... it works very well. All of my little issues around the balcony are now solved ! Thanks a lot to both :)
balcony.thumb.jpg.123cd3853928e8c6587eeda1c43cef3a.jpg... and why do I have that clear wood color in my Bottom Rail instead of "Beige Stucco" like exterior side ??
where, how can I change this like MarkMc last balcony posted ?? Thanks
    27475
    slickrick1530
    slickrick1530
