Door casing question
jonboy
I have noticed on exterior doors or a garage door that the casing does not attach to the wall it attaches to the stone, changing the depth of the jamb does not affect the casing .... I want the casing on the wall ... am I missing some setting?
X9
I think he wants it showing on the Sheathing as Normal Eric , just not out on the Stone Work
Is this a Pony Wall ? perhaps it is showing the wrong half in Plan view?  though it seems to work for me....see below
Do you have "Fit Jamb to Wall" checked ?
P.S.   there is an anomaly with Doors if you don't put a casing on each side , like default per garage Doors , so visually in 3D they don't appear correctly ( janmb is split/broken) so I just add a thin one so the 3D builds correctly eg 1/2 x2"
