Designer1 Posted October 27, 2017 Share Posted October 27, 2017 Does anyone know why in X7 but not X9 in the room DBX under the room names and show room labels theres an option for display in uppercase. I thought this was a helpful feature...was it moved somewhere else or deleted altogether? Link to comment Share on other sites More sharing options...
NRST8TRKR Posted October 27, 2017 Share Posted October 27, 2017 My room names always display in upper case no mater how I type them in. I was thinking it is that way by default. have a great evening ,Ken Link to comment Share on other sites More sharing options...
Dermot Posted October 27, 2017 Share Posted October 27, 2017 The short answer is that you can now control whether or not text is always uppercase through the Text Style. I would also recommend that you checkout the reference manual. Just click on View Reference Manual from the Help menu. I did a quick search for "uppercase" and found the section in the manual discussing this under "Files Created in Version X7 and Prior": Quote 2. Uppercase Text The Uppercase option was added to Text Styles in Version X8, whereas in Version X7 and prior, it was an option for Room Labels and Schedules only. In legacy plans opened in Version X8, any Schedules present in the drawing will be assigned a Custom Text Style, as will their associated Schedule Defaults. If any Schedule Default is set to Use Layer for Text Style and no objects are present on that layer, a new Schedule Text Style will be created and assigned to that layer. Room Labels are treated similarly: if any are present, they and their defaults will use a Custom Text Style. If a given Room Label or Schedule has been sent to layout more than once and was set to use different Text Styles in each layout view, it is possible that its appearance may be affected in some views. See “Text Styles” on page 507. Link to comment Share on other sites More sharing options...
Designer1 Posted October 27, 2017 Author Share Posted October 27, 2017 Thanks for the replies. Dermot thanks for posting this. I guess I didn't realize the change was on such a global platform for the new versions...I initially just noticed that option being gone so I wanted to ask about. Thanks for the detailed descriptions of the changes! Link to comment Share on other sites More sharing options...
