K80Guy
I don't like the Gable Accents Chief includes.  Can I get someone to build me a version of this that I can adjust manually for different gables?  I build these onsite without the 2x materials.  Just the lower portion.
Thanks for the help.
Gable_Bracket_51T2_12_12_3_1_2__27378.13
If I'm not mistaken Alaskan_Son did a nice video
demonstrating how to build that. The bad news is
that I wouldn't know where to start a forum search
for said video. Perhaps you should look him up or
vice versa.
Do you have a shop drawing of a standard one that you use with a few measurements of the detail and stock size ?
You can follow this steps to create one with your dims.
1- open new plan and shoot elevation
2- draw the shape of all members(except the center piece) using cad poly lines and convert to poly line solid
3- draw the profile of your center piece using cad line and add it to your library. Use that molding line in plan view by click and drag to its plan dimentions and that is done. Finally position it to where it should be.( follow the video if you are not familiar with step 3, I hope creating PL solid using cad lines and converting it to p.s is quite easy)
4- Convert it to symbol, go back to your plan, put it there and done.
Here is a short video on how to
(Major area of concern here is step 3, hope the rest is straight forward using PS)
O
  • Upvote 3
