Electromen Posted September 18, 2017 Share Posted September 18, 2017 View in Chief Architect’s 360° Panorama Viewer. I've done many Ray Traces at the same settings but this one has a haze it and can't figure out why. No focal blur set Link to comment Share on other sites More sharing options...
rlackore Posted September 18, 2017 Share Posted September 18, 2017 Check to see if you have Bloom enabled. Link to comment Share on other sites More sharing options...
Electromen Posted September 18, 2017 Author Share Posted September 18, 2017 11 minutes ago, rlackore said: Check to see if you have Bloom enabled. No Bloom and Image Properties are at default. I'm trying again from scratch. Link to comment Share on other sites More sharing options...
Electromen Posted September 18, 2017 Author Share Posted September 18, 2017 I started a new Ray Trace using the Launch Assistant and the haze is gone. Not sure what was causing it. Link to comment Share on other sites More sharing options...
WendyatArtform Posted September 19, 2017 Share Posted September 19, 2017 With raytrace going or done - Image Properties - if "use tone mapping" is checked, an exterior can appear hazed in. We always check interior (otherwise will look harsh), and always uncheck exterior (otherwise appear flat/hazy). This may or may not be your issue, but worth checking and certainly worth understanding. Tone Mapping applies some algorithmy stuff that changes your image by trying to do what it thinks is balancing. Somebody at Chief can 'splain it better. But if you look at these images, you'll see that it makes a clear difference. Link to comment Share on other sites More sharing options...
