ChiefuserMathews Posted September 9, 2017 Share Posted September 9, 2017 Hello I am trying to create a stair for one of my client as per the attached image which the client's wants to get achieved. How do I create the end landing which is seen in the attached image? I am a new user of the chief architect. Any help is much appreciated. Thank you Link to comment Share on other sites More sharing options...
Chopsaw Posted September 9, 2017 Share Posted September 9, 2017 You can create a landing from any shape of Polyline but you will have issues duplicating the curved composite decking that way. I think I would build the whole landing with poyline solids. Depending on the level of accuracy you require you could build a deck or three all on separate levels and then make the curved decking with a face profile rotated about the center of the arc of the deck and a copy of the same face extruded the other way for the straight extras. Then maybe replace or cover the framing with a polyline solid and some lights. A lot of custom work but it can be done if you take the time to learn it. Quick proof of concept pictured but it would take a bit more time to complete. The upper tier will be the easiest because chief will work for those border planks. Link to comment Share on other sites More sharing options...
ChiefuserMathews Posted September 9, 2017 Author Share Posted September 9, 2017 Thank you so much for your quick reply. Let me try that. Thank you Link to comment Share on other sites More sharing options...
