Window Shape
crazytrajan
Likely a symbol is your only chance but that is what symbols are for...  Custom stuff.   Psolid for glass and solids for the frame or a molding polyline would do it all in one shot.   :)
On second thought it might not be any advantage to make a window symbol as it will create issues with the wall opening.  I just made an architectural block that you can have and edit or check out to see how to make your own.  I would try making the wall opening with two wall material regions or Joe's Hole in the wall tool and then just turn the framing off or custom frame.
Chevron Window Block.calibz
  • 4 weeks later...
