SteveByars Posted August 11, 2017 Share Posted August 11, 2017 How can I create an L-shaped wall opening as shown in the attached picture? I've tried mulling doors and windows together but always get a section of wall/frame between them. thanks! Link to comment Share on other sites More sharing options...
dshall Posted August 11, 2017 Share Posted August 11, 2017 Better yet, put ina 3070 doorway and then to the side put in a 3040 pass thru, I think you will get what you are after. 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted August 11, 2017 Share Posted August 11, 2017 21 minutes ago, solver said: Or maybe there is an easier way? Only slightly... Don't use a doorway and a pass-through, just use 2 doorways. Copy and paste the second and adjust height as necessary. It will frame a little better too. Link to comment Share on other sites More sharing options...
SteveByars Posted August 11, 2017 Author Share Posted August 11, 2017 Thanks! I ended up using the two doorway method and it worked the first time. Link to comment Share on other sites More sharing options...
