ACADuser Posted August 2, 2017 Share Posted August 2, 2017 Tried the WINDER option but no can do. Is the 2 stair objects the only method that works? I do not want the stair overlapping the garage wall in plan view. Davis.zip Link to comment Share on other sites More sharing options...
glennw Posted August 3, 2017 Share Posted August 3, 2017 Alan, Winders will work, but they only work when contained in a room. So...create a room around the stairs with invisible walls. Link to comment Share on other sites More sharing options...
ACADuser Posted August 3, 2017 Author Share Posted August 3, 2017 Thanks Glen Yes you can build it with invisible walls but you can not build the stair to fit that house. I'll sent to tech support. Link to comment Share on other sites More sharing options...
