tchomes
Attic Wall Changes Between X8 and X9?
I opened a plan in X9 this morning that I completed in X8 back in January.  To my suprise, the attic walls for the dormers are sticking above the roof and the windows in that area are messed up.  I have noticed this happening before with older plans that we use to modify.  I decided to take some time this morning and look through the forums and try to determine what is going on between X8 & X9.  We have so many more issues with X9 and attic walls and auto dormers.  Something apparently changed...
See photos below of what is appearing when I open the file in X9.  I can open in X8 and it appears correct.
I assume some simple setting that I need to fix when opening these older plans.  I appreciate the help so I can quit scratching my head and placing blame somewhere else :)
You didn't think to post the plan?
    27374
    GabriellaS
    GabriellaS
  • Similar Content
    • By jessde
      x9   intermediate skills
      Can someone explain how to configure text in other than a straight line?
      Thanks for any help offered.
      J
    • By PinnacleChief
      Good Morning!  I am upgrading to x11 this week and wanted to know what to do with x10 and x9 on my desktop.  Can I move these over to a zip drive and retrieve them later if I need to view an old plan that I made?  I'm trying to free up some space on my computer.  I haven't used x9 since I upgraded to x10, so I'm assuming that once I upgrade to x11, I won't be using x10 either.  What do you guys do?
      Thanks,
      Jim
    • By Ajay44
      No longer using the software so I am selling it for $1600.00 or best reasonable offer. I will handle the license transfer and fee. If you are interested, give me a reply and we can discuss the details.
    • By frameworks
      **I contacted customer support and found my answer.
      when you send your view to the layout if it is in no scale like before now you just have to hold the "x" key and grab the corner to resize. Hope this saves someone some headache**
      I have not seen this addressed anywhere but I am hoping someone figured this out.
      In all previous version of Chief if you pulled the corner blocks with your layout scale turned off you could resize windows to their relative scale but in X10 that changed to altering the view window of the image or imported plan segment.
      If anyone could tell me if there is an option to still use the original corner pull tool it would be much appreciated.
