Does anyone have a .pat file for an arabesque tile pattern that they'd like to share with the rest of the class?  Even just tips for writing the code for patterns such as this (curved lines in particular) would be most appreciated.
**Plan B**
Are there programs out there that will take hatch patterns drawn with CAD lines and turn them into the text files needed to import as .pat files?
You guys have always been rock stars when it comes to CA solutions.  Hoping there's some constructive feedback out there somewhere.
Thanks!  Matt
    27860
    Emileen
    Emileen
  • Similar Content
    • By Renerabbitt
      POST 0
      You've found it! A thread offering up some of my favorite symbols and content for Chief Architect X-11.
      These items are for X-11 only. If you haven't updated yet I encourage you to do so, it's a great release.
      The following content is listed by category with both a link to the post within this thread for easy navigation and a link to a direct download if you won't to cut straight to the chase. new/recent uploads are in RED font
      CLICK ON THE "DL" FOR INSTANT .CALIBZ DOWNLOAD:
      CONSTRUCTION ASSEMBLIES/ARCHITECTURAL ITEMS:
      RABS 42 CABLE RAILING - DL    RABS MODERN FRONT DOOR AND DOOR ASSEMBLY - DL   RABS INTEGRATED SINK - DL NEW!!! 03/26/2020
      ENTOURAGE:
      RABS CHARLES-HILL GROUPED LIVING ROOM - DL RABS CHELTON GROUPED LIVING ROOM - DL    ACCESSORY HOME #1 - DL ACCESSORY HOME #2 - DL ACCESSORY HOME #3 - DL
      KITCHEN RELATED:
      3-ISLANDS - DL LA CORNUE 1908 RANGE - DL CAFE APPLIANCES, PAINTABLE(CORRECTED) - DL
      LIGHTING:
      PENDANTS AND SCONCES - DL-1 - DL-2 - DL-3 - DL-4 RECESSED NC HALO 4 INCH LED WITH HOUSING - DL NEW!! 03-22-20
      MATERIALS:
      TILE AND COUNTERTOPS #1 - DL 1(ONEDRIVE LINK) - DL-2 CUSTOM WHITES WITH PAINT TOOLBAR ICONS - DL-1 - DL-2 - DL-3 - DL-4 - DL-5 - DL-6 RABS RUGS 1V1 - DL          RABS STARTER KITCHEN MATERIALS PACK - DL         RABS FLOORING PACK 1 - DL            RABS OLD GOLDEN OAK FLOOR - DL
      SYMBOLS:
      FIREPLACE ASSEMBLY 1 - DL     ACKLES BED AND EDISON TABLE LAMP - DL-1 - DL - 2 TEAPOT MATERIAL EDITOR REPLACEMENT - DL-1 - DL-2 FINMARK TABLE FROM CB2 - DL FIREPLACE MANTLES 1 AND 2 - DL    RABS STRETCHABLE PICTURE FRAMES - DL
      VIDEOS:
      YouTube Channel
      Many of these I have personally made or modified. Some of the content may have been created by others for which I will give credit. Many of the materials have free licensing, so no credit is needed.
      Some of this content may slow down your program as I have a high powered machine and often times use complex and high resolution textures. I will try and give as much detail as possible. Use at your own peril!
      No but seriously dig through and enjoy, I've spent a good number of hours ensuring the quality of these symbols and will update them periodically- so CHECK BACK IN! and PLEASE GIVE A LIKE FOR THE POST OF ANY SYMBOL YOU LIKE, IT ENCOURAGES ME TO GO BACK AND REFINE/REDUCE/OPTIMIZE THAT SYMBOL. GIVE A DOWNVOTE AND IT'LL PROBABLY ENCOURAGE ME TO DO THE SAME THING...YOU'LL JUST BE A JERK FOR IT
      CHANGELOG:(PACIFIC TZ)
      Page 1:
        Post 0:
      02-12-2019- 4:45PM: Removed the poll, migrated this thread. re-uploaded from X11 public beta 02-20-2019-2:59PM: Added a Poll for user content requests 03-30-2020-6:49PM: Deleted Video Links and added link to YouTube Channel   Post 5:
      02-12-2019- 4:45PM: centered the hearth on the symbol   Post 18:
      02-12-2019-9:52PM: Posted and fixed DL links
      Here is a symbol to get you started:
      @Cheryl_C_Crane Think you requested this,
      RUSTIC BRICK 2.calibz
      Number of Textures: 2
      Map size: 1024x1024
      Filesize: 3.13 MB
    • By rembocanoe66
      I've used CA for years and AutoCAD since 1985. (Yeah I'm old).
      In Florida we do a lot of Block house plans. (CMU) 8x16x8 concrete blocks.
      Other than manually placing block patterns. Does anyone have an easy way to do wall fill patterns to show the ACTUAL CMU BLOCK Pattern in plan view.
      It would be great if it actually placed filled cells required for all window/door openings and corners. Any suggestions?
      Thanks
      Ray
    • By robdyck
      Is there still no material that will allow transparency in Vector View? I use a lot of glass for deck railings and its completely insane what needs to be done to make an exterior elevation drawing look decent. Currently, I need to build my railings without any glass, then build the glass manually, place on a separate layer so I can have it on in renderings, but off in elevation views (vector). Then, in elevation view, I need (choose) to manually draw p-lines with transparent fill to show the glass without blocking visibility of the structure beyond.
      I don't like fighting Chief's defaults and auto features, but I also want my drawings to have a certain appearance. Anyone have any thoughts or tips for transparent glass (not windows) in vector views?
    • By Luciano
      Hi everyone,
      Is it possible to create more then one new material at the time?
      I have in a folder filled with wood grain pictures (vertical & horizontal) and I would like to add them all to my library but doing it one by one will take forever... From what I see in the program, there doesn't seem to be a way yet. But I imagine or hope that someone found a way to do it.  I must not be the first user who wants to do that to save time. Any idea everyone?  Thank you.
    • By ginamk
      Hi,
      I'm having an issue with X9 - anytime I open an item and try to change the material type, I get a pop-up box that says "searching for files" and it appears to be searching through my file folders, but it's on a continuous loop searching the same folder endlessly so the search message isn't going away and I have to force stop the program. I've tried opening different files to see if it was just happening with a possibly corrupt file, but it's happening with several different files so I don't think thats it. I called the help line and they are not familiar with the problem. They said I should try my luck here.
      Anyone have this problem?
