buzzsaw204 Posted June 8, 2017 Share Posted June 8, 2017 hi, is there a option to Build / Rebuild the pile layout. like the way CA have the Build Floor Framing?? when you adjust your walls, and click Build Floor Framing, it will rebuild the floor framing to the new wall. is there a way to do that for the piles.... for when you adjust you foundation wall. then you can rebuild you Pile accordingly. Link to comment Share on other sites More sharing options...
Kbird1 Posted June 10, 2017 Share Posted June 10, 2017 If you are using a Grade Beam Foundation and have Auto rebuild Foundation on in the Floor Defaults it should.... If you drew those manually with CAD circles no, don't think so....... but you should be able to group select them and move them over with transform/replicate>move Link to comment Share on other sites More sharing options...
