Chopsaw Posted May 12, 2017 Share Posted May 12, 2017 I am trying my best to learn auto Roofs but seem to be having an issue with presetting in defaults the thickness of my rafters in the Structure tab. I can successfully change the width and even the material but not the Thickness. Also trying to add a layer of structural sheeting and a layer of rigid insulation but nothing seems to be read from the default settings when building or rebuilding the roof plane. Seems to be stuck at 31/2" for some reason. I just updated and still have the same behavior. Any ideas? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted May 12, 2017 Share Posted May 12, 2017 Away from my computer and I obviously don't have a plan to look at so this is just a guess off the top but it sounds like you might have trusses checked. 1 Link to comment Share on other sites More sharing options...
Chopsaw Posted May 12, 2017 Author Share Posted May 12, 2017 Wow, Thanks Michael that was magic. I must have done everything else 30 times over including a reboot. Much appreciated!!!! Link to comment Share on other sites More sharing options...
