Greg_NY61 Posted May 3, 2017 Share Posted May 3, 2017 I'm trying to clean up my PC, and I ran WinDirStat program and I see that I have in ProgramData\Chief Architect Premier X8\Referenced Files folder a bunch of library zip files which amount to tens of GB. Do you need this files for any reason or they just there for when library files being installed and can they be deleted? Thanks! Link to comment Share on other sites More sharing options...
Dermot Posted May 3, 2017 Share Posted May 3, 2017 Quote Do you need this files for any reason or they just there for when library files being installed and can they be deleted? These are all textures and images that are used by your library objects. If you remove them, you may have problems with library objects and will likely see errors about missing files. You should probably not remove anything from the ProgramData folder manually. This data is installed by the program or gets put there when you download libraries. If you wish to remove any of your libraries, you will usually want to do this from within the program. Link to comment Share on other sites More sharing options...
Greg_NY61 Posted May 3, 2017 Author Share Posted May 3, 2017 Thanks for clearing that! I was just wondering what they were and I thought that textures and everything else related to the library items are packed into calibz file. Link to comment Share on other sites More sharing options...
