Pony Wall Brick Returns
brentjohn
I confirmed the door is recessed.
However, I did not have the exterior casing working - I was using a poly line for the trim.  I deleted the poly line and added the exterior casing.  The right side is working (see photo).  However, the left side is not showing the casing and has not changed (see photo).  I've also attached the plan view for the entire length of the garage door opening.
59008ed904b2c_PonyWall-BrickElevationView-Rightside.thumb.JPG.bb9b890212e6a25c390247f090c2a1dd.JPG59008ee25d0b5_PonyWall-BrickElevationView-Leftside.thumb.JPG.9f8e7cf4a72399fba59d8192c885dbae.JPG59008eea4183a_PlanView.thumb.JPG.c22e7389fe7a673ea28b3b6f8e65828a.JPG
4 minutes ago, brentjohn said:
rlackore,
Thank you for asking.
Wellesley_L 4-26-17.plan
Do not build the garage front wall in 3 segments.
Select garage door,  copy,  drag left wall to the right so you have one wall, garage door disappears,  paste in place and garage door is back.  All is well.
Do not build the front wall in 3 segments...  it is  one wall.
590093d242f96_ScreenShot2017-04-26at5_32_35AM.thumb.png.fa88762bf1578c61ee286ac28359046a.png
