brentjohn Posted April 17, 2017 Share Posted April 17, 2017 Greetings, I'm new to the Chief family - purchased Premier 9 on Friday. I have struggled all weekend with trying to figure out how to place a wall under cabinet counter top. I've attached a photo of what I have. I would like for the counter top to cover the wall. Link to comment Share on other sites More sharing options...
justmejerry Posted April 17, 2017 Share Posted April 17, 2017 You can use a railing wall and set your height or you can draw a regular wall and pull the top down in section/elevation view to your desired height. Link to comment Share on other sites More sharing options...
justmejerry Posted April 17, 2017 Share Posted April 17, 2017 Should also note you may want to use custom counter top to get overhang you want. 1 Link to comment Share on other sites More sharing options...
brentjohn Posted April 17, 2017 Author Share Posted April 17, 2017 Thank you much for the response. I did create the wall as a railing wall (see below). As well as modified the counter top (see below). Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 17, 2017 Share Posted April 17, 2017 You're missing the step of creating a CUSTOM COUNTERTOP (like Jerry said). Open Help and search Custom Countertop. Link to comment Share on other sites More sharing options...
parkwest Posted April 17, 2017 Share Posted April 17, 2017 Brent, welcome to the forum. I have found the best and first place to look for help for most questions is the knowledge base which you can find under the User Center tab. Link to comment Share on other sites More sharing options...
brentjohn Posted April 17, 2017 Author Share Posted April 17, 2017 Alaskan_Son, That is what I was missing! Again, thank you ALL for your help!!! Link to comment Share on other sites More sharing options...
