Problem with Deck Railing Cuttting Wall Surface
WoodlandDesign
Hello all.
I am having a very strange problem with the deck railing wall function.  As you can see in my screen capture the deck railing is 'cutting' the exterior wall surface material leaving a void.  This is where it get interesting:  It only does it where the LEFT deck railing meets a wall not on the RIGHT!
I have tried many things including rebuilding the walls, using the Edit Wall Intersection function, changing the lock wall function, etc.  I am scratching my head and don't understand what I'm missing or if this is a common glitch of the program.
Any help would be appreciated!
Thanks in advance
Picture on left shows problem.  Same railing on right, no problem?
.58f125f9363b9_Untitled1.thumb.jpg.0d3272fd302f2a824d2b4c6f9995fa12.jpg58f1265f81989_Untitled2.thumb.jpg.81aa616f42335fb956079bf2d0a901e6.jpg
you must have used p-solids for the lower railing ,I guess, sometimes I will have a solid railing and need a w.i. railing on top or fill in a space with railing and you can't have two walls in one space unless you make one wall a non-def. wall.
