DBearss Posted March 30, 2017 Share Posted March 30, 2017 Working on a project that needs horizontal louvered light shelf. I found the vertical louvers but cannot rotate. They could be flat like an outdoor trellis. Anybody have any suggestions? Link to comment Share on other sites More sharing options...
DBearss Posted March 30, 2017 Author Share Posted March 30, 2017 something like this; Link to comment Share on other sites More sharing options...
DBearss Posted March 30, 2017 Author Share Posted March 30, 2017 or this; doesn't need to be exact. Actually the coat rack would work if I could make it thicker. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 31, 2017 Share Posted March 31, 2017 Tons of ways to do this... 2D molding 3D molding 2D molding AND 3D molding (2D for the slats and 3D for the supports) Primitives and multiple copy Symbols and distribution path Deck framing (sneaky method) Louvered window converted to symbol and rotated Rotating existing louver symbols through symbol dbx. (not sure which louvers you were referring to that you found)... Also, you could use any combination of the methods above...and I'm sure there's a whole slew of other methods I'm not even thinking about. Those are just the ones that very quickly came to mind. Link to comment Share on other sites More sharing options...
DBearss Posted March 31, 2017 Author Share Posted March 31, 2017 Ended up making it out of a coat shelf and a beam. Simple enough. The library is so vast I was just surprised there wasn't one already. Onward! Link to comment Share on other sites More sharing options...
ACADuser Posted March 31, 2017 Share Posted March 31, 2017 It in there some where. May be an add on library. Link to comment Share on other sites More sharing options...
ACADuser Posted March 31, 2017 Share Posted March 31, 2017 Oops, could not find a way to rotate it. try 3D warehouse Link to comment Share on other sites More sharing options...
