contractcad Posted March 26, 2017 Share Posted March 26, 2017 I think I've seen other users have a similar problem but don't remember seeing a solution. Please look at the attached file and note where I have my trench footings intersect at the corners of the basement walls. I REALLY DO NOT want my trench footings to intersect into my block walls, I want them to stop at the block wall. I did already check "through wall at beginning" and "thru wall at end" for the all 4 basement block walls which did correct the 1 inside corner, but not the two outside corners of the basement walls. Is there a simple way to solve the problem? Highland NAPA 2.plan Link to comment Share on other sites More sharing options...
Richard_Morrison Posted March 26, 2017 Share Posted March 26, 2017 Add a short invisible wall (room divider) at the end of the trench walls. (Well, where you want the trench walls to stop.) You may have to play around with the "Edit Wall Layer Intersections," too. Link to comment Share on other sites More sharing options...
Richard_Morrison Posted March 26, 2017 Share Posted March 26, 2017 Eric deserves the point, since his answer is illustrated. Link to comment Share on other sites More sharing options...
lbuttery Posted March 26, 2017 Share Posted March 26, 2017 Quote Chief deserves a negative point as this shouldn't be happening and should have been fixed long ago Lew Link to comment Share on other sites More sharing options...
contractcad Posted March 26, 2017 Author Share Posted March 26, 2017 Yes, Richard and Solver's work-a-round seems a bit rinky-dink but it works. Thanks much! Link to comment Share on other sites More sharing options...
