sharpe_c Posted March 11, 2017 Share Posted March 11, 2017 Greetings The framing at 45 degree corners is not mitering as it would be built in practice... as 2 - 22.5 degee cuts... I am trying to detail some tall walls and the framing is not showing up as I wish and I cannot seem to change angle on end of plates to reflect reality..Help Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 11, 2017 Share Posted March 11, 2017 I made this video to cover your issue and one other issue for another user. I used a 90 degree wall intersection but the same basic principle applies. You have to use the Edit Wall Layer Intersections tool... Link to comment Share on other sites More sharing options...
Chopsaw Posted March 11, 2017 Share Posted March 11, 2017 Post a screen shot or a sample plan and someone will take a look for you. The miter tool still needs some improvement to be perfectly accurate. It usually works in 2D but is often a different story in 3D. You may need to draw in some polyline solids if you need something custom exactly represented with precision. Link to comment Share on other sites More sharing options...
