johnny Posted February 27, 2017 Share Posted February 27, 2017 When working on a roof structure, should adding thickness result in the roof extending into the living area below? I am working a different elevation for a project already modeled differently expect I am changing the roof structure to something that is going to be much thicker. I suppose I could just raise all the roof plane "z" height, but I feel like I may be missing something having to do that. Link to comment Share on other sites More sharing options...
Chopsaw Posted February 27, 2017 Share Posted February 27, 2017 Yes, I believe that if you have edited an automatic roof plane and turned off auto rebuild it will lock the roof plane and build down on you. You could turn auto rebuild back on but that is a whole new can of worms likely in your situation so transform and replicate is possibly the best solution at this point. See :https://www.chiefarchitect.com/videos/watch/1501/locking-and-protecting-roof-planes.html?playlist=95 starting at 2:30 min. 1 Link to comment Share on other sites More sharing options...
