blayman Posted February 25, 2017 Share Posted February 25, 2017 Help, seems like I'm having a senior moment this morning. Trying to update my profile plan and and get the following error message Take Read Only Attribute off your plan, or use save as to save under different name. I can't find where to remove the READ ONLY attribute. Thanks for all help. Bill X9 version Link to comment Share on other sites More sharing options...
lbuttery Posted February 25, 2017 Share Posted February 25, 2017 Bill: PREFERENCES - FILE MANAGEMENT - DISABLE FILE LOCKING in general you want file locking on to prevent you or others from working on a file in two places it is possible you have that file open somewhere else in your PC ? sometimes accessing the file for something else will keep the lock on even tho you closed it there try doing a restart of Chief and if needed a restart of your PC if all that fails then try DISABLE FILE LOCKING be sure to turn it back on as soon as possible Lew Link to comment Share on other sites More sharing options...
blayman Posted February 25, 2017 Author Share Posted February 25, 2017 Lew, Thanks, it finally went away after closing both chief and shutting down the computer. Bill Link to comment Share on other sites More sharing options...
