Corner window help
mthrift
I'm using Premier X8 on a Mac
When I add a lintel to the corner windows it adds a weird casing trim to the right of the right window, but not the window to the left of the corner. If I remove the lintel, it disappears but I need the lintel.
If I recess it to the sheathing layer, which is really where it needs to be, the lintel doesn't extend from the sides. And the funky trim is still there, just hidden in the stone layer.
My plan is too big to attach here. So I have attached images, the left image shows the funky trim piece it is adding. The right image, I have recessed the windows to the sheathing layer and you can see the sill sticking out of the stone to the right of the window.
Thank you in advance!
