Seven10 Posted February 15, 2017 Share Posted February 15, 2017 I know there is a simple answer to this, but its driving me batty. As soon as I draw a room divider between two walls, the room divider wall takes on the characteristics (width and and name) of the wall its connected to. Its still a room divider and separates the room, but now its 5in thick and I can't change the wall type back to room divider - no matter what I do. Its got to be something dumb, right? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 15, 2017 Share Posted February 15, 2017 Room dividers seem to increase to a full thickness wall whenever the rooms they are dividing are structurally unique. To avoid this problem, create a room divider of your own and set the thickness to 1/512" thick. This will round down to zero in the dbx. but the wall will actually retain some thickness so it's size will not change on you. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted February 15, 2017 Share Posted February 15, 2017 Room dividers will only stay as is ,if there are no differences in heights (floor or ceiling). It will frame the space between those hights Link to comment Share on other sites More sharing options...
Seven10 Posted February 15, 2017 Author Share Posted February 15, 2017 OK, all of that makes more sense now. I'll give it a whirl. Link to comment Share on other sites More sharing options...
