Line with arrow and text line with arrow problem
capitaldesigns
I am having a problem with both the line with arrow and text line with arrow command. I am getting two arrows.
When I make a turn in the line with arrow I get two arrows, one at the turn and one at the end of the line.
This has been happening the last couple of days. It never happened before.
Does anyone know how to fix this so I only get an arrow at the end of the line.
Thanks,
Mike
I just check, It is not toggled off. I just found out that if I draw a few straight lines with arrow then draw one
with two segments the problem goes away.  I do not know if the problem will come back again.
I will let you know in a little while. I am in the process of converting hundred's of details I have drawn in
AutoCAD over the last 23 years. I will be using a lot of line with arrows since most of the AutoCAD arrows
did not convert over to CA arrows.
Thanks,
Mike
It's still happening. I was able to get 3 text lines with arrow correctly before it started again.
I saved everything and closed the program then restarted it up again. I was able to get one
two segment line with arrow before it started placing two arrows again.
I guess I will have to call tech. support tomorrow morning.
Thanks,
Mike
