ACADuser Posted January 26, 2017 Share Posted January 26, 2017 I have a house where I had to lower the first floor ceiling 8" & the floors above dropped 8" . I had a framing plan https://skfb.ly/XSqC But I do not want to rebuild ALL the framing for fear some of the modified framing will be removed. How do you lower the floor trusses & roof without messing yup the rest to the house framing? I have already selected the walls floor by floor & rebuilt them. Also most if the exterior walls are block walls. How would you display an outline for the block walls so you an tell they are there but not block the view of the framing? Erasing surfaces is too tedious & not permanent in the 3d view. Thanks Link to comment Share on other sites More sharing options...
ACADuser Posted January 26, 2017 Author Share Posted January 26, 2017 Well I did an ALL OFF & turned trusses only selected & Moved them -8" seemed to work OK Link to comment Share on other sites More sharing options...
DRAWZILLA Posted January 26, 2017 Share Posted January 26, 2017 you can also select the truss tool and hold down shift, while holding the shift drag a box around the area, it will only select the trusses. Link to comment Share on other sites More sharing options...
