El_Hefe Posted January 24, 2017 Share Posted January 24, 2017 Hi, I am new to Chief Architect and I am working with version X8. When I try to create a room of type "Open Below", I get a strange result: The walls between the two floors have a gap. This first image shows the room that I want to convert to "Open Below": After selecting "Open Below", the floor disappears (as expected), but it leaves a gap in the walls: How can I close this gap? I already tried to modify the floor height of this room (Room Specification -> Structure), but that did not work. Regards, El Link to comment Share on other sites More sharing options...
ACADuser Posted January 25, 2017 Share Posted January 25, 2017 Post a plan. But looks like you have an extra hidden wall on the 2nd floor. Link to comment Share on other sites More sharing options...
El_Hefe Posted January 25, 2017 Author Share Posted January 25, 2017 Plan is attached to this post. This problem occurs with every room in the 2nd floor. OpenBelow.plan Link to comment Share on other sites More sharing options...
Chopsaw Posted January 25, 2017 Share Posted January 25, 2017 Just move your Plasterboard wall layers so they are not part of the Main Layer. Heighlight and move in the DBX (Dialogue Box) as shown below and you should be good. Link to comment Share on other sites More sharing options...
El_Hefe Posted January 25, 2017 Author Share Posted January 25, 2017 Hi, thank you, that resolved the problem. Link to comment Share on other sites More sharing options...
Chopsaw Posted January 25, 2017 Share Posted January 25, 2017 Also check your cross sections when you frame and you may find that you will also want to move your "OSB" out of the main layer so the floor frames correctly. 1 Link to comment Share on other sites More sharing options...
