Ray trace ?
jonboy
Either way still turns out with either shadows or to dark ... tried Direct sunlight intensity at 1 or 0 then that dark
Turn off the sunlight then is to dark  ...
Tried with sunlight off and direct sunlight at 4 still dark
Nothing seam to work in turning off the RT shadows/sun .... should be someplace to turn off in RT
Still need help
You should be able to boost the ambient light level under 3D View Defaults if you have "Use Camera View Settings" checked in the Raytrace DBX, increase the "Uniform Intensity" in the Raytrace DBX and you can also boost things with the "Image Properties Settings". If things are still too dark then you could add a few 3D lights.
Here's one I just Raytraced. Direct Sunlight Intensity "0", all lights turned off. Boosted Intensity & contrast in Image properties. 60 passes in 2 minutes.
Graham
