Joe_Carrick Posted January 12, 2017 Share Posted January 12, 2017 I have found that un-blocking a CAD Block can cause a disconnect of Leader Lines from their Text in certain cases. It doesn't happen in all cases but when it does it is repeatable. I have reported it as a bug - waiting to hear from CA about a fix. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 12, 2017 Share Posted January 12, 2017 This is a major problem and I have reported it in the past as well. Acfually the leader lines sometimes get disconnected from their text and sometimes they get disconnected from the object. Sometimes they will even move to another object. It can make for a real mess. What I've resorted to doing usually is exploding the block in another view or CAD detail and then cutting/pasting into the new view. One of my custom tool sets requires accurately placing a cad block initially though so in that situation I create a cad detail from view, place the block in that, explode it, and then cut/paste hold position into the real view. In that particular case I can continue to hit Control+Alt+V for additional copies of the exploded block as well. Link to comment Share on other sites More sharing options...
