capitaldesigns Posted January 10, 2017 Share Posted January 10, 2017 I am working on a tenant plan and I am getting the broken corner symbol at the end of mu cursor. I can not find the broken corner. Is there a way for CA to indicate which walls are the problem walls ? Or is there a way to turn off the broken corner symbol at the end of my cursor. Thanks, Mike Link to comment Share on other sites More sharing options...
glennw Posted January 10, 2017 Share Posted January 10, 2017 You can turn the indicators off at Preferences...Edit...Behaviors...Behavior Indicators. Probably better to leave them on though that icon is telling you there is a problem. Have you tried Build...Wall...Fix Wall Connections or Connect Walls from the Edit toolbar when a wall is selected? Link to comment Share on other sites More sharing options...
capitaldesigns Posted January 11, 2017 Author Share Posted January 11, 2017 I just tried both of the methods you suggested and nothing happens. This happened right after I used the wall trim tool to remove 48" of a wall next to a corner. The corner walls next to the section of wall being removed appear to be correct. I have one of the remaining walls back from the corner so they do not connect. I then get 2 circles appearing where the walls use to connect. When I reconnect the walls together again the circles disappear, but the broken wall symbol still shows up at the cursor. I'm not sure what the 2 circles indicate. Thanks Mike Link to comment Share on other sites More sharing options...
capitaldesigns Posted January 11, 2017 Author Share Posted January 11, 2017 Glenn, I found the problem wall. It was highlight by a circle at the problem intersection. This building is 140,000 s.f. I have been working on some offices on the other side of the building. I do not know how all of a sudden a wall on the far side of the building got screwed up since I am not working on that section of the building. Thanks for the help, Mike Link to comment Share on other sites More sharing options...
