Importing Survey Data In Pnezd (Comma Delimited) Format
palommy
I have data from a property survey that is in PNEZD (comma delimited) format in a text file.  I am having difficulty importing it into my project.  Do I need to somehow convert the file to another format?
Hi:
check Chief's MENU - FILE - IMPORT for available formats
I don't think PNEZD is available as a choice
but I do think there is a CSV choice
maybe change the extension to the CSV format Chief can recognize (do this to a copy of the file)
or try to find a conversion utility to change the PNEZD to one Chief can use
or try "save as" from the software that created the PNEZD file as a format Chief can use
Lew
In Chief, PNEZD is the #,Y,X,Z,D Format or CSV where Y is the Northing and X is the Easting - Z is the Elevation & D is Description. As long as your PNEZD file does not contain extra letters or text lines it will import under import Terrain Data.
When I attempt to import using the #,Y,X,Z,D format, I get the following error message: C:\p4sync\dev\Releases\16.3\chief\source\importterrainwizard.cpp(379): Warning #272032042
"An error was found on line 445 while parsing the file."
6/13/2014 10:22:01 AM
Build: 16.3.0.59x64
Line 445 or point # 915 has no comment. Fix that and data imports OK. The First number in a line is a point number not a line number.
Your data has a lot of zero elev points--- you may want to look at it again. Also some points are spread way out beyond a typical lot. Grouping is very bad.
Gerry:
you beat me to it :(
beyond my forte :)
Lew
  • 2 years later...
