MilkmanCDN Posted December 27, 2016 Share Posted December 27, 2016 Hello, I'm importing some furniture from 3d warehouse and my problem arises when applying materials to the furniture pieces. Specifically, the material pattern looked stretched/zoomed on some pieces, but not on others. Plan, material, and 3d models attached. I've inserted a screenshot of two pieces of furniture with no material applied and with. Note the top-right piece that seems odd. Would someone be able to open the plan and confirm the odd behaviour that I'm seeing? Thanks. Natuzzi-Cult-2575-000.skp Natuzzi-Cult-2575-001.skp Test Plan.zip Link to comment Share on other sites More sharing options...
Chopsaw Posted December 28, 2016 Share Posted December 28, 2016 Yes I can confirm but not explain that behavior for you. If you make a copy of the material to apply to the chair without the arm (001) you can set it to about 2.5" x 2.5" rather than the default 20x20 and deselect stretch to fit and it should give you a reasonable match. Link to comment Share on other sites More sharing options...
MilkmanCDN Posted December 28, 2016 Author Share Posted December 28, 2016 Stellar! I'll try that in the morning. Thanks. Link to comment Share on other sites More sharing options...
MilkmanCDN Posted December 28, 2016 Author Share Posted December 28, 2016 So I think I've got this nailed down to a problem in the sketchup model. Some models show the odd material sizing. Some don't. But more importantly, I've found one model where some components of the model size incorrectly, and some do. Natuzzi-Klaus-2086-294.skp Link to comment Share on other sites More sharing options...
Chopsaw Posted December 28, 2016 Share Posted December 28, 2016 I see that you could not wait until the morning. Maybe a Sketckup user could weigh in and explain. It is maybe possible to edit in Sketchup? Link to comment Share on other sites More sharing options...
johnny Posted December 28, 2016 Share Posted December 28, 2016 So what i've done before is to make a layer system in SU on an object that matches the "material" delineation you want. Even if materials are the same, if you want a different direction than in Chief it has to be a different material listing. If you just isolate the surfaces into different layers before you export it should resolve all of this. I've been able to import files into CA without doing all this, but when i've had issues I revert to the method above to resolve issues. Link to comment Share on other sites More sharing options...
smashing Posted October 19, 2022 Share Posted October 19, 2022 I realize this is a very old topic but I experienced a similar issue to this today. When importing a 3D model (symbol) and applying a material to it in Chief Architect, the material appeared stretched compared to other objects and walls that I applied the same material to. In my case I was importing a Collada (.dae) file made in Blender. The solution for me was to disable 'Use Imported UV Map' in the symbol specification dialog when importing, which comes up if you select advanced options. This solved the problem immediately. Link to comment Share on other sites More sharing options...
