Member Statistics
Similar Content
By woodcraftdesign
using live camera views in layout, how do I change the size of these in the layout sheet. I would like my renderings to measure 12" wide but I cannot change the size. Probly just an oversight on my part.
By kylejmarsh
How can I speed up layout? Seems ridiculous that moving some text WITHIN LAYOUT and not even touching my synced viewports has such an awful lag time. I have a fast computer and the modeling is plenty smooth. I also have used lots of other cad software and even old, clunky dried-up CAD software doesn't have the terrible lag that working in Layout has.
I've devised ways around it - trying to do everything in my model and nothing or as little as possible in Layout - but this is just bad and seems unnecessary. What is going on within the code when moving text like this takes a few seconds?
Is this common or am I an outlier? I've posted a video of the lag time here - can anybody else corroborate this lag? Is it time for a (nother) computer upgrade, or will even DeepBlue have a similar lag time? Is it some secret setting within chief that is slowing me down like this?
Screen Recording 2021-03-01 at 3.31.31 PM.mov Screen Recording 2021-03-01 at 3.23.19 PM.mov -
By JamesKCI
Hey all,
Sorry for the slight tongue-twister of a title. I'm here with another novice question.
When creating roof plans to send to layout, I'm running into an issue. After I choose to display all of my roof planes on the same level, they appear as though the program is deliberately displaying the lower roof planes on top of those that should be above. I've attached a couple snips showing an example of how one of my roof plans is drafted and another two with what that plan looks like in plan view. It's in the roof plan view but it looks the same regardless of the layer set I use.
Much Obliged
By Sunnyfields
I am trying to do a presentation plan and am using a top down orthographic view with watercolor and overlaid lines. I can't get the resolution I need exporting an image from CA so I have sent the view to Layout as a live view. We also tried it as an image. The problem is that every time I try to create a PDF two walls disappear. The view box is large enough, so I haven't cropped the view, I've had our veteran Chief guy look at it, and we're stumped. Here is the result:
Here is the view in Layout:
And Here is the print preview:
Has this happened to anyone else? I have tried outputting this about a dozen times and the same two walls are cut off every time.
I am running CA Premier X12 on a Dell with these bells and whistles. I also have Bluebeam Revu as my PDF print driver in addition to the "Export" function in CA. I have tried to print and to export with the same result . Any help would be appreciated.
By Ange822
I am drawing a cross section using 2D CAD lines (to get more detail than the automatic cross section Chief creates).
I am having issues finding a Batt Insulation Pattern to use.
I am using Chief X9
- Chief Architect has a Block under "CAD Blocks / Detail Components / Insulation / Batt / 5.5" R-21", but unfortunately it is only 12" x 5 1/2" of size, so if I want a smaller or bigger section, it stretches the block and the proportions change.
- I found a free .PAT file online (attached), but It needs to be in a specific location to work, the minute I move the polyline with that pattern in it, the pattern moves with it.
I have tried to illustrate this in the attached screen shot.
Please let me now if anyone has any recommendations / solutions to this issue.
thanks,
Angela
H1INSUN1.pat
