Cabinet Defaults
Joe_cul
Before I started a plan I changed the cabinet defaults with the white wrench. I wanted a dark color. When I was all done. I thought it was too dark. I changed the defaults, again with the white wrench, to a lighter color. No change in the plan.
If I change a single cabinet to lets say white, then select it. I click the white wrench with the red plus sign to change the defaults. No change.
It seems the only way I can change the cabinet color is to change one cabinet, then use the I dropper on the remaining cabinets.
What version are you using? works in X8 for me. Tested with cabinets from all three locations- core library, kitchen and bath toolbar, and standard drop down icons. Defaults did not always work with all of those, don't know when they changed it but glad to see they did.
