Fastest way to create a layout page using a structural PDF or DWG file
DCB123
You can import DWG details [or pdf] into a library or plan file.
>Need to make sure that it won't violate other users copyright infringement either
Best way: will be create your own, use [modify] the detail chief architect provided, ask if someone will share with you here, etc.
If someone provided something to you, ask/check license statement "free to use in any commercial..."
TYP details are the same, so copyright is about the author.
The easiest way to include TYP CAD details on the layout  ... is to create a separate plan file with all of the details, link this additional "details" plan
with a layout file and use send to layout for your details to be sent to a layout. This would allow you to update a single "details".plan and an update
will reflect onto every layout this detail plan is linked to.
