basilbabaa
.Skp Door
Import as a Doorway Symbol (advanced)
In the Symbol dbx:
Rotate 90 degrees about the z-axis
Set y origin to 30"
Opening Width as 12'
Plan View Width as 12'
Sizing Stretch Plane y=48
You won't be able to see it "Open", and it will be listed in the Door Schedule as "Doorway" bu you can edit the Comments in the Component dbx.
Note, if you Import it as a Door instead, it will act like a Garage Door but you will need the y-origin to be about 22" to sit flush with the exterior wall surface.  In addition, Chief will draw the dashed line in Plan as if it was a Standard Overhead Garage Door instead of a Roll up.
    28327
    NorthRiverHogan
    NorthRiverHogan
