Sign in to follow this
MrDaveAres
Erasing Library Catalogs
Quick and easy question.  If I delete CA installed library catalogs while creating a new template, will those catalogs be forever gone until I reload CA X8, or will the catalogs be there when I open or start a new plan from my original template?  Thanks.
I would be careful not to delete anything you are concerned about loosing or do not want to reload as I believe the library is not template specific.  Sounds like you might benefit from doing a little research on "Library Filters".
 https://www.chiefarchitect.com/videos/watch/1926/productivity-tips-using-the-library-search-and-filter-tools.html?playlist=81
Hello,
Thank you for the question.  If you delete one of the Bonus, Manufacturer or User catalogs you will need to re-install the deleted catalog.  The Core catalogs are locked and can't be deleted from the library.  As mentioned above, the library is not template specific, so deleting a catalog is a global change.
I hope this helps.
Kind regards,
Derek
Chief Architect Sales
    27499
    Bren0625
    Bren0625
