Lighthouse Posted October 22, 2016 Share Posted October 22, 2016 Help,I have read everything online to no avail! I have a house with lots of exterior walls, that I want to be different materials and textures. I know that I can click on an individual wall and change it's material, but that is really time-consuming in this plan with so many walls, when I want to experiment with different siding colors and textures. So I want to be able to use the eyedropper to copy a wall material and paste it onto another wall. The problem I'm having is that when I use the eyedropper, it just changes the color of the new wall, not the material. For example, I have a wall made of horizontal wood siding. On a different wall, the exterior wall material is brushed aluminum sheets. When I use the eyedropper to copy the aluminum, and then paint it onto the wood sided wall, it just changes the color of the wood siding, but i can still see the siding. It doesn't replace the wood siding with the aluminum sheet. Is there a quick way to copy the material of one wall and paste it onto another, without having to open up each wall and choose the materials? I know I have done this before, but now it won't work. btw, I have tried all the different material painter modes Thanks Link to comment Share on other sites More sharing options...
Alaskan_Son Posted October 22, 2016 Share Posted October 22, 2016 You have to uncheck Blend Colors With Materials (the little paint roller icon). I recommend unchecking this in your profile plan and leaving it unchecked except in very rare circumstances. Link to comment Share on other sites More sharing options...
Solution dshall Posted October 22, 2016 Solution Share Posted October 22, 2016 You have to uncheck Blend Colors With Materials (the little paint roller icon). I recommend unchecking this in your profile plan and leaving it unchecked except in very rare circumstances. That is the answer Link to comment Share on other sites More sharing options...
Lighthouse Posted October 22, 2016 Author Share Posted October 22, 2016 Thanks so much!!! I checked that box when I was experimenting and forgot to uncheck it. Link to comment Share on other sites More sharing options...
